How materials looks after rendering depends on many things. The material in the material slot is quickly rendered with some (internal) settings and a simple environment.
You already will see in this prerender if you change the environment that the appearance of the material also changes.
In your project you have all kinds of things that change the appearance of materials, the (colored) lights you use, other materials around (e.g bleeding) shadows and then some possible render settings. And after render is complete you can make some changes by using tonemapping..
So yeah, that a material in the slot looks different that in the render is to be expected.
Louis
Please mention Revit version, especially when uploading Revit files.
