Material Browser not loaded properly
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1332 Aufrufe, 7 Antworten
Installed & re-installed Revit 2019 on windows 10 a few time but problem could not be resolve. My Material Browser loaded seems incomplete: No options, no buttons, cant expand browser panel. Please see attached images.
Anyone has the same encounter? Please advice.
7 ANTWORTEN 7
Nachricht 2 von 8
RDAOU
als Antwort auf: Anonymous
That is the material browser you get when you use paint tool
The other one which you are looking for you can find On the Ribbon >> Under Manage tab  >> Materials
Nachricht 3 von 8
Nachricht 4 von 8
als Antwort auf: barthbradley
Hi Yes,
but there was no response from that thread posted several weeks back.
Nachricht 5 von 8
@Anonymous wrote:
Hi Yes,
Did you go to the tread I posted?  The guy there was having the exact same issue as you. He even posted a similar screenshot to yours. He resolved by re-installing the Autodesk Material Library -- which I also posted a link to. Did you see that link that I posted?  It's underneath the other link I posted.
Nachricht 6 von 8
als Antwort auf: RDAOU
Hi, I don't use paint tool.
This is what I get from Revit > Manage > Material.
The icons/buttons on the material just does not show.
Nachricht 7 von 8
ryanLMYD6
I had this same issue. I use a laptop and plug into two monitors that are 4K resolution. To fix the problem I had to mess around with the display scale. Here is what I did:
-Go to Display Settings
-Advanced scaling settings
-Enter custom scale of 149
-Apply (and repeat for the other screen if you have multiple screens)
Nachricht 8 von 8
als Antwort auf: ryanLMYD6
HI Ryan, Thanks. I lower my screen resolution and it works. Quite a illogical remedy though. Anyway, Thanks again.
