In materials browser I'm having trouble coming to terms with the "graphics" vs "appearance" tabs.
I'm not currently technically doing any rendering in revit and probably will not have that need going forward.
So, the appearance tab settings are generally out of the box although I do change some for my purposes.
I understand the rendering settings in some way determine the way the model shows up in 3D views.
For my visual styles I don't currently use the "realistic" option and primarily default to the "consistent colors" option.
What I'm having trouble understanding is how the "use render appearance" tick box, under SHADING on the graphics tab affects my model when it's turned on and off... since I'm not technically using shading.
It looks like that when I select the tick box the 3D model assumes all the settings for the colors that it "can" for the "consistent colors" selection but other than that I really don't understand what it's doing.
