Material Browser , Appereance , Texture Editor, Scale. Problem!!!
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
barkin.celiker
474 Aufrufe, 10 Antworten
Hi
I am trying to design a kitchen and i downloaded a dishwasher.  I am trying to add the panel texture where you can see the switch on/off buttons and other functions.
To do that, i uploaded the image that comes with the dishwasher family but the uploaded image was showing multiple times like a tile, so I was editing the panel material by clicking material browser=> Apperance=> Generic-Image=> Texture editor. I entered the right measurements in the scale section and disabled the tile selection under the repeat.
It looks perfect in the texture editor but after I click done and apply. The panel is still tiled showing multiple textures and the image in the appearance tab is not updating from the texture editor.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: barkin.celiker
Have you seen it in the actual family in the project? Maybe it is just the preview that was wrong. You can also use the image as a decal instead of a material.
Nachricht 3 von 11
MachielAEC
Are you editing this in the family or project? Might be a display bug, would save and close to see what it does when opening up again.
Machiel Odendaal
---BIM Enthusiast---
Nachricht 4 von 11
Tile the Image and paint it on a 52.50cm x 9.80 cm surface - or use it as the Material for a 52.50cm x 9.80 cm Geometry (e.g. solid extrusion).
Nachricht 5 von 11
you sure about those dimensions?  Seem awfully large for a dishwasher control panel.
Nachricht 6 von 11
FWIW: when I bring the image into a Project as a Decal with locked proportions, the height is 9.015cm (not 9.80cm) with width at 52.50cm.
Nachricht 7 von 11
barkin.celiker
als Antwort auf: MachielAEC
it is the saved and closed openned up version.
Nachricht 8 von 11
Nachricht 9 von 11
barkin.celiker
als Antwort auf: barthbradley
Hi Barth
https://www.bimobject.com/en/electroluxbrasil/product/LL10X
this is the familly i was working with. I didint know the decal function. i managed to do it with the decal.
Nachricht 10 von 11
barkin.celiker
als Antwort auf: ToanDN
Decal did the job , i didint know about it thanks a lot. But i am still confused why my uploaded 52.8cm to 9.8cm image doesnt fit in to the panel and tiles automaticly even though the tile option is none.
Nachricht 11 von 11
@barkin.celiker wrote:
...and tiles automaticly even though the tile option is none.
Where do you see it tiling?
