Material Appearance showing in realistic view but not rendering
lucasfcangussuJQQ8L
lucasfcangussuJQQ8L
Hello everyone.
Ever since I updated from Revit 2020 to Revit 2022 I've been having an issue rendering using cloud services where some of the materials fail to find the associated path.
As you can see in the images, the materials are showing normally on a realistic view, even are displayed properly inside de material manager (the example shown is the material I applied on the outer facade walls).
If I use the rendering option inside Revit 2022, I get only a few material errors but every important one loads normally. If I use the cloud rendering option instead, a massive list of missing material paths and the rendering turns out mostly white.
I've tried deleting all the rendering paths and manually re-adding them, and after a few tries i managed to get a few images to render properly using the cloud yesterday. This worked after I added each individual type of texture folder, instead of the main folder that contains all the other folders. Today I resumed working on this project, not having changed anything else since it last worked, and the materials have stopped rendering using cloud service again.
I do not know what else to try, any help would be greatly appreciated.
Thankfully,
Lucas Cangussu.
syman2000
Have you tried adding custom path for all your previous texture map location and see if that helps.
lucasfcangussuJQQ8L
Hello, thanks for the reply. Yesterday I added all the possible texture paths one by one, and yesterday it was working as intended. As of today they have stopped working again, and I haven't changed anything today.
This is what I have now, a lot of individual folders selected.
