materal image not showing in realistic and rendering
3 ANTWORTEN 3
Nachricht 1 von 4
ChrisGamble
286 Aufrufe, 3 Antworten
Problem:  A material I created is not showing the image in the realistic graphic style and it is also not showing when I render
The process I followed:
-I created a model in place element with a material
-Went into the materials browser
-Duplicated a material
-Copied the material aspects so it doesn't edit the original
-checked "use render appearance"
-Applied a image for the material
3 ANTWORTEN 3
Nachricht 2 von 4
SallyDong2005
als Antwort auf: ChrisGamble
This looks like a Revit problem. I would like to move it to Revit forum for here has more experts would be helpful.
@ChrisGamble could you share your model or a test file contains the problematic material ?
Sally Dong
Nachricht 3 von 4
ChrisGamble
als Antwort auf: SallyDong2005
I actually already posted the same question in the revit forums and received the solution. I figured this forum was more for rendering but then realized there are less active revit users in this forum so I went ahead and reposted it there.
Nachricht 4 von 4
ChrisGamble
