Matching Room Colour To Schedule
8 ANTWORTEN 8
Nachricht 1 von 9
darren.nelsonCLKV3
2932 Aufrufe, 8 Antworten
Hi, We have set up a conditional format so that rooms can be identified visually in the schedule if they are over/under a required area.  Is there anyway to have a layout matching this so its easier to see whereabouts on the plans these over/under rooms actually are?  It would also assist flagging up any changes in model room size that then meet or do not meet the criteria.
Beschriftungen (2)
8 ANTWORTEN 8
Nachricht 2 von 9
hmunsell
als Antwort auf: darren.nelsonCLKV3
if you turn on the Room Interior Fill from the views Visibility/Graphics overrides, you can create a view filter that should do that.
then apply the filter to the view settings and set the Pattern color as needed.
Howard Munsell
Nachricht 3 von 9
Thanks but that doesn't seem to work as you cannot assign a parameter into the box where you have 100SF.  It has to be an amount or a formula starting with =.
Our schedule is set up so the Area Under or Area Over columns only display a colour if the difference between a parameter Area is different to the parameter SOA Target Area.  The Area Over and Area Under parameters are only set up in the Schedule Properties as a field.
Nachricht 4 von 9
hmunsell
Ya.... unfortunately you cant have a formula in a Filter that I know of.
Maybe a Dynamo script?
Howard Munsell
Nachricht 5 von 9
Can't you get there with a Color Scheme Definition that uses Room Area  by Range? Something like this:
Nachricht 6 von 9
what about using Colour Range Scheme for Rooms with Colour> Area by Range
Constantin Stroescu
Nachricht 7 von 9
Those don't work either, sorry.  All they do is look at one parameter when what we need is a the outcome of a calculation which is only set up in the schedule.  If we could get the calculated column to appear in the colour scheme filter then we might stand a chance but it doesn't show.  Possibly got someone seeing if its is achievable via Dynamo but he says it isn't automatic, we would need to re-run the script everytime the layout got changed and thats prone to being forgotten about.  Aarrggh
Nachricht 8 von 9
and/or use a combination with a Conditional Formatting for different Fields...
Constantin Stroescu
Nachricht 9 von 9
bew4KAB2
als Antwort auf: barthbradley
I need to do the same, Did u find a way?
