Match Lines subcategory
Consultant Consultant
Message 1 of 10
I thought I struck gold with Match Lines's subcategories because I need lines to show on different Views without having them as model lines.  Then the reality struck when I couldn't find away to assign the new subcategory to any Match Lines I drew.
Replies (9)
Message 2 of 10
Sahay_R
Me too. The only thing I could find out that worked was overriding graphics in view.
Makes me wonder what is the point of the Matchline Subcategory if we can't assign it? Is it any better in 2018?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
Viveka_CD
Hi @ToanDN and @Sahay_R
Thanks for pointing out this issue!
I see what you are saying about this tool.
Let me see if I can extract some information from the developers with regard to assigning match-lines and subcategories, and if there is a in-progress functionality in the latest version.
Message 4 of 10
Thanks @Viveka_CD!
Message 5 of 10
Sahay_R
Looking forward to it, @Viveka_CD!
Rina Sahay
Message 6 of 10
Viveka_CD
Hello @ToanDN and @Sahay_R
Below is an update from the team regarding the match lines subcategory.
  • Few customers change their matchlines via the contextual menu > Override in view > Element.  They can also hide the matchlines in this way, if needed. Alternatively, some customers put matchlines in multiple worksets for additional on/off control.
  • However, It may be possible to allow Matchlines to have an instance parameter that uses its subcategory - a project that a scrum team would need to take on and prioritize.
Posting to the ideas station is recommended to gain votes - will follow up from there based on priority.
Message 7 of 10
Viveka_CD
Hi @ToanDN
Please add this request to the IDEA forum. We will prioritize from there.
Message 8 of 10
RyanHarvey-FMB
Observer
Observer
Contrary to what it says, this is not actually solved. Just another request for changes.
Message 9 of 10
Thanks for your idea. Great work.
You will find few more ideas when you check these questions: Scrum master interview questions
Message 10 of 10
daniel.bulyovcsity
For whoever looking for better control of visibility of matchlines, just use headless multi segment gridlines. They are kind of same but with many more options. You can control their height in uncropped sections when it says "3D" next to them.
