Anuncios
Massing - Division by refference plane dissapears after a massing Cut
No aplicable
I have a few simple extrusions that represent the building facade and they are divided into modules by reference plans and grids.
I am using a list of these references for the division of the face.
When I cut the masses to create the proper shape, many of the lines disappear!
How can I do this basic massing operation successfully without deleting the reference lines from the reference places?
https://knowledge.autodesk.com/community/screencast/2d4abf82-f8e7-4718-84ec-60cd34b90408
0 Me gusta
Responder
Soluciones aceptadas (1)
884 Vistas
12 Respuestas
Respuestas (12)
No aplicable
I've made an example file to test.
It seems like if a mass's face is cut or joined ob both side, it goes bonkers and is unable to understand reference cuts from lists.
0 Me gusta
ralvarez1976
The reason its failing is because you have a spacing rule in the divided surface that is conflicting with the intersects. These conflicting rules are trying to create a division in the same place on the surface. Click the divided surface and turn the U and V Grid layouts to "None." Then intersect it with the levels and grids and they should all work.
0 Me gusta
No aplicable
Oh my god I think that actually worked....
The Autodesk Support just told me it was a limitation of massing. Thank you so much!!!
Now, I'll see if it works in our giant building complexes.
0 Me gusta
No aplicable
Actually that did not work at all and just created a bunch of other problems and holes.
0 Me gusta
No aplicable
You can see both in the image below
Left has 1 for UV, Right side has none. Both are failures in their own different ways.
0 Me gusta
No aplicable
@Viveka_CDCan you make this unsolved again please?
0 Me gusta
ralvarez1976
Can you explain what you are expecting as the result again? It is not clear from your images. Also, go ahead and post a sample file.
I agree with you that Conceptual Massing has problems. However for the geometry you are working with it should work fine because it is planar and not double curved.
0 Me gusta
No aplicable
There should be a division where I highlighted in orange, since the level is supposed to divide there.
The sample file is supplied in Post 2. Please let me know if you have any other questions.
0 Me gusta
ralvarez1976
See attached file. Is this what you mean?
0 Me gusta
No aplicable
Yes.
I've noticed that adding no UV division creates missing panels however. It`s like its failing in a different but similar way.
0 Me gusta
ralvarez1976
Ok, so your original question is solved, correct? This is now another issue. Please open another thread and post this file so someone can help you.
0 Me gusta
No aplicable
Solución aceptada
Yes.
So that people know, the solution was to remove the U and V division by setting the division to none.
0 Me gusta
