Hello All,
I need help, please.
I would like to design, in REVIT 2015, the type of mass that you can see in the pdf file (Picture 1 in attachment on this).
What is the best way?
Thank you so much.
Best regards.
Antonio
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
looks like a very simple sweep. What is it attached to? There are several ways to do a sweep?
Thank you for your interest.
Yes, it's a sweep, but I'm not able to do it.
I have an example in Revit 2017, please tell me how to do the same way.
Thank you so much.
Bye.
Antonio
Create a sweep path with Ref Lines, and then draw a sweep profile on a Ref. Line work plane perpendicular to the path. Then pick the path and profile and Create Form. Easy breezy. I did one for you in the attached file. Hope it helps. If not, you can find video tutorials online.
