Mass subcateogires
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Jun_Nagase
1217 Aufrufe, 4 Antworten
Mass subcateogires
I need your help in how to use Mass subcategories.
I can understand how to use Mass Floor, but I cannot figure out how to use -exterior Wall, -Glazing, -Interior Wall, -Opening, -Roof, -Shade and -Zone.
I tried to change the subcategory per face, it assigns to the whole instance, and strangely, it disappears after editing.
I checked the categories are turned on in V/G.
この投稿が参考になりましたら、「いいね」をお願いします
この投稿で問題を解決できましたら、「解決策として承認」をお願いします
Jun Nagase / 長瀬 純
Associate
Nikken Sekkei Ltd.
4 ANTWORTEN 4
Nachricht 2 von 5
kadmonkee
als Antwort auf: Jun_Nagase
the image you show is from Object Stylescheck the settings in Visibility graphics
what are your Settings set to  for conceptual Mass
options are
Show Mass by View Settings
Show Mass Forms and Floors
in Visibility Graphics, is the Mass box checked (on)
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 5
One mass family (in place or conceptual) can only belong to one subcategory.  You cannot have different parts of a mass assigned to different subcategories, which is sort of defeat the point of having them.  I had submitted an idea to allow improve it in the Idea forum in my signature so if you want you can go there and vote for it.
For now, mass subcategories are there so you can assign to different masses (not parts of them) in order to control there visibility under VG.
Nachricht 4 von 5
Jun_Nagase
als Antwort auf: kadmonkee
kadmonkee,
Thank you very much for the reply.
"Show Mass by View Setting" worked to make those massing to be appeared in a view.
Jun Nagase / 長瀬 純
Associate
Nikken Sekkei Ltd.
Nachricht 5 von 5
Jun_Nagase
als Antwort auf: ToanDN
ToanDN,
I think I am clear the intention of these subcategories.
Till now, since it was a conceptural "massing", I've been using it to study a volumn of a builing (usually one form).
But utilizing these, we can design more in detail (to the certain extent) by sub-dviding the shape into other parts (wall, glazing, shade, etc).
Jun Nagase / 長瀬 純
Associate
Nikken Sekkei Ltd.
