mass round edges
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
Karol_Piroska
1675 Aufrufe, 11 Antworten
mass round edges
I need to create a fairly complex curvy geodome like roof shape using mass and I came across a silly problem (something that should be very basic). Is there no other way to round edges of a mass other than creating void sweeps? I thought I did it previously, but that must had been in CAD.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Karol_Piroska
Got pictures?
Nachricht 3 von 12
Karol_Piroska
als Antwort auf: barthbradley
@barthbradley, it would be smilar to the one attached. It was supposed to be a few minutes work - L shaped mass box, round the edges, divide the surface, apply adaptive components etc etc ... and I couldnt believe I never came across the rounded edges issue (or should I buy stronger coffee?)
Nachricht 4 von 12
Easy. You can model it with 2 domes + 1 L (half circle profile) connecting the domes, join them.
Nachricht 5 von 12
lucdoucet_msdl
@Karol_Piroska
Maybe contact the manufacturer, Geometrica?
@ToanDN
The shape is a bit more organic than regular geometric solid swept and/or assembled.
I'm thinking of an imported NURBS surface for such an irregular surface.
-luc
Nachricht 6 von 12
Karol_Piroska
als Antwort auf: lucdoucet_msdl
thanks.
yes, it is slightly more complex than interconnected domes.
That image is from geometrica, but at this stage I need to produce it myself. I'll try loft between several profiles and if that doesnt work an imported surface could help, just not sure how it will behave in Revit.
Nachricht 7 von 12
I'm fairly certain that I could get there in the Conceptual Massing Environment.  Definitely not something I could just whip out in a few moments -- no matter how strong the coffee.
Nachricht 8 von 12
@Karol_Piroska wrote:
thanks.
If it cannot be created from a composition of primitive forms then you can loft multiple horizontal profiles (layered cake), or vertical profiles (sliced bread).
Nachricht 9 von 12
@Karol_Piroska: Are you actually Planning its construction?
Nachricht 10 von 12
syman2000
To construct that complex shape, you have use create reference plane and give it name
Place points on the ground level and use spline thru points
Go to profile, add points and then spline thru points
Once you have the profile, set it to reference line so the skeleton will be there once you create your form. As well I would spline thru points in opposite direction to create skeleton form below. Reason is if one side failed to create loft, the other side will able to create your form.
Once you create your shape, you can adjust your shape by  moving the point around
Then you divide your surface and now you can add adaptive pattern to your form
Nachricht 11 von 12
Karol_Piroska
@syman2000 , thanks, that seems to be the best approach. Loft between several profile, adding profiles etc didnt work.
Nachricht 12 von 12
syman2000
Revit can be very unperdictable with the profile. Sometimes you have to make it far apart and less angle. Once the loft shape is created, you can move it closer and it won't break. It is weirdest behavior I've encounter.
