mass problem
mass problem
mass problem
I've a problem with mass elements.
engineering team placed ouside falls with masses.
This masses are good solution but we just cant see them good. they are shown gray. I try ALL .
VO, element vo, category vo,  materials, filters .... they are still grey.
Our project is set in MEP part, Mechanical temp.
Please help me :X
www.TechRoom.bg
Mass element are always gray in MEP part. Its a problem but for now you cant change basic options like color on mass element in MEP part-mechanical.
Easyiest way is to switch to coodinate view for making coordination.
Or if you need to see those masses in your plan view with (for example massive black line) you just can use detail line.
I hope this will help you!
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
