Mass Modeling Question
Hi
I have started using massing and built a "conceptual mass" model then loaded it into a revit "Project" but when it loaded the model was see through ( like a wire frame but not) i have checked the settings but it does not change.
can anyone help me better understand.
Darren
Kimtaurus
This is normal behaviour.
You'll have to assign materials if you want "solids". And yes I put solids between brackets as a mass remains hollow.
Massing is ussually used as a guide for placing walls/floors/roofs.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Cheers
im still new to this massing thing.
Look into the default mass form, mass floor, mass etc... In the materials.  They all are semi transparent.  And for good reasons.
