mass doesn't let void cut. can i import a floor into a mass?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
587 Aufrufe, 4 Antworten
my mass isn't letting me void it.
the mass itself is inside a big project and in it i know where exactly i need the void. inside the mass file, i don't know because there's no indication.
is it possible to somehow import a floor from the big project into the mass fam?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
A void and a solid must be in the same mass in order for them to interact.
In your case, you can export the project's floor to a CAD or SAT file and import it in the Mass so you know where to create the void.
Nachricht 3 von 5
System Families into a Mass Family? No, not directly.  You might be able to get there by Exporting the System Families in the Project to DWG, and then inserting the DWG into the Mass.
Nachricht 4 von 5
als Antwort auf: ToanDN
read my mind. exactly what i'm trying to do now. hope it works, should work!
Nachricht 5 von 5
als Antwort auf: barthbradley
my thought just a few minutes after i wrote the post. working on it, hope it works!! :leicht_lächelndes_Gesicht:
@barthbradley
