Mass Divide Surface - Nodes On Intersection Points
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
Hugh_Compton
822 Aufrufe, 1 Antwort
Hello
In the attached file is an in place mass.  I am trying to get the nodes to show up on the intersection points but I am missing something?  I have used the divide by 'Intersects List' which does divide the surface as I intended.
1 ANTWORT 1
Nachricht 2 von 2
Hugh_Compton
als Antwort auf: Hugh_Compton
OK, I've worked it out! I needed to disable to grids BEFORE using the Intersects List....!
