How do we edit concrete masonry unit or block dimensions in Elevation and Section views of masonry walls ?
As you can see from the Screenshot attached, they are all different sizes in my model, for no apparent reason.
I would like to standardise them all at 41cm x 21cm and/or cut blocks.
I had hoped it would be something like tile patterns o the floors, but it isn't
Thankyou and regards
Peter
Gelöst! Gehe zur Lösung
Gelöst von peterdew. Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
It seems that these walls were splited and that is why the hatch pattern made a mess.
Checks if the the hatch pattern is in the size you want in the material's appearance setting and. try only to align the patterns with the tool align.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
It shows the wall type's material model surface pattern, you can edit it to change that. If you need a custom model pattern you could use addin such as PyRevit or use hatchkit/pattycake online i.e. There are several topics on that on the forum.
You can download patterns, load autocad .pat files if you have them i.e. or custom create your own. Which dimensions are you looking for exactly (in elevation), running bond I guess?
Ow, this definately should be improved. But for now we'll have to do with add-in's I suppose. It's a real shame you can't export the .pat file at least, so I totally agree it is definately too limited... without those add-ins that is... You can create them with just a texteditor though if you're a little familiar with .pat files... But let us know what you need we'll figure it out.
Thanks again, Martijn,
but all I want is a running bond pattern where the horizontal courses are at 21cm vertically and the length ways horizontal dimension is 41cm, allowing for blocks 20 x 40cm with 1cm joints in both directions, so that I can position doors and windows in detail on the elevations with the blocks showing.
If I had the option to increase the joints or reduce the block dimensions, so much the better.
Surely that must be easy ?
Peter
reagrds
Peter
thankyou, Mauricio,
but that is far too complicated to me, even though they have an example of exactly why I need it;
placing windows in between the blocks in a normal block wall.
I would have said that an editable running bond pattern is the least that could be expected from Revit,
if not all the other standard brick and block patterns as well.
regards
Peter
Peter
you can use align tool to handle it for the beginning of construction and create reliable model and u can check that all brick use same material and if u can check the dimension of Brick from material window from Manage tab.
Thankyou, but when you say link in, do you mean copy her in the hope that she sends me a suitable file plus the information regarding how to load it direct ?
regards
Pete
that's what I had expected too, Mohamed, but you can't.
The pattern dimensions never shows up in an editable format.
regards
Peter
Not as easy as it ought to be, but I'll link in @Pattycake_Kyle to help you get the hatch pattern(s) you're after. You might want to look into an addin for hatches though. Can't create it for you myself at the moment unfortunately or would have done so already.
Here's the link for doing it the hard way:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Thankyou again, Martijn, but that link literally makes me feel ill,
despite having exactly what I want as an illustration.
Even AutoCad Release 12 from 1992 was easier to follow than that,
and I could use it 20 years ago with Pro-Reflex, but not anymore,
despite still have the manual.
I'll have to wait for Pattycake_Kyle to reply, hopefully;
regards
Peter
peterdew@eim.ae
Hello again, Martijn;
just to be clear, i would have thought we should be able to dimension the surface pattern as attached and edit the dimensions to what we want
regards
Peter
Hello, Martijn;
I never heard from Pattycake,
and now I got a follow up from AutoDesk;
am I satisfied with the replies ?
Well; no, obviously.
thankyou and regards
Peter
@peterdewSorry, I didn't see your previous messages. I would suggest installing the pyRevit addin so you can make/draw your own patterns within Revit, it is quite useful and you could do some more stuff which could be useful awell. Unfortunately I don't have it with my latest install yet. edit: Let me see if I can switch system.
I just had a brainwave and discovered that the blocks show more or less correctly under Realistic View. I will have to consider if I can use that rather than the hatch pattern, where I may want to edit the picture.jpg dimensions a little
