Hello, I want to do a masking region (totally white) over a specific region here. however under sheet that tool is disable.. how can i do it?
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
Make the Filled Region on a drafting view >> group >> then place the drafting view on the sheet to mask the region/part of the sheet which you need to hide
Masking regions are not allowed in sheets.
You can create a Generic annotation family which has a white filled region and use it instead.
Mostafa Elashmawy
The generic annotation of a solid white filled region method works, but it's not very adaptable. Is there a template for ADAPTIVE generic annotations? I'd like to be able to pick the 4 points around what I want to mask, and generate the overlay.
Great idea!
I tried creating a legend with a masking region as they can pasted to multiple sheets (if they repeat).
