Masking region not work incase using join
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
kohei.yonehara
460 Aufrufe, 2 Antworten
Hi all,
I'd like to hide wall around column, so that, I'm using masking region in the column.
Basically it works, but when I join the column and above slab, masking region not work.
Does anyone have solution for this?
*I don't want to cut wall for column.
Thank you very much.
Beschriftungen (4)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: kohei.yonehara
Why don't you just join the geometries together in the correct join order. Join geometry will remove volume at the union. A masking region doesn't.  All's a masking does is hide the overlapping geometry.   Not very BIM.
...if you must, nest the Masking Region (Detail Item RFT) into the Column Family.
Nachricht 3 von 3
kohei.yonehara
@barthbradley
Thank you very much for your reply.
I couldn't join this geometry as some reason.
But, nest filled region family was worked.
