Masking region no masking fill pattern
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
laverdadozharalibres
1640 Aufrufe, 6 Antworten
Hi, does anyone know why my furniture (which have a masking región inside the amily) isn´t masking the fill pattern applied to the material on the floor?, im sure the furniture is above the ground plane, so is not an overlapping geometry issue, i tried whit several visual configurations and i can´t solve it,
Pls help :enttäuschtes_Gesicht:
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: laverdadozharalibres
Visual style = Hidden or Wire frame?
Nachricht 3 von 7
als Antwort auf: ToanDN
Well, it is set to hidden line, i realized  that when i zoom in the view this happens, but when i zoom out the masking región on he familly looks as it should, im printing in pdf now, im gonna see how it goes
Nachricht 4 von 7
Ok this is weird, when i print to pdf the masking region looks like is working but instead of obscuring the hatch on the floor, it just makes it ligther, maybe is beacuse im using the "halftone" option on the whole furniture category from the visibility and graphics override
Nachricht 5 von 7
Check the Furniture category graphic overrides and View filters and see if they have any % of transparency.
Nachricht 6 von 7
Looks almost like the furniture is in an Underlay.
Oakwood Flooring + Bed on Level 2.  Bed on Level 1.  Level 1 is Underlay.
Nachricht 7 von 7
you are rigth my friend, i am underlying the level above which has the same fill pattern tan the level on the view, so i guess i just need to hide it, thank you very much :leicht_lächelndes_Gesicht:
