I am trying to map autocad shx fonts to Revit. The help file... http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-87119589-ADE4-41AD-A796-3EB3C1DDDA82 ...says to find this file: "shxfontmap.txt "
I can't find it anywhere. The path they reference it being located at ...
"AutoCAD SHX fonts are stored in the following location: C:\Program Files\Autodesk\AutoCAD <release>\Fonts+
... does not exist. I have searched the entire computer for "shxfontmap.txt". Nothing.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Hi @steve
Depending on whether you installed Revit as a standalone or deployment, the location may vary. try under the following folders:
C:\ProgramData\Autodesk\RVT 201?\ It should be under UserDataCache folder
if not above try under %AppDATA%\Roaming
Thank you for such detailed responses. BUT... I let the r2017 install to default locations. I can find no folder called ProgramData anywhere using search or visually at the c: root or any other drives root, nor any of these anywhere on any hard drive. Mystified. https://goo.gl/iSxfMW
Also no folder in search of any drive called RVT2017 or RVT 2017 https://goo.gl/Ul44w2
Its like we are talking about different programs.
I am using windows10 search, with "all subfolders" selected. Is there something I don't know about search function? https://goo.gl/RIsx8b
It is a hidden folder... Just copy the and paste in the window explorer
C:\ProgramData\Autodesk\RVT 2017\
if not in the above copy paste the following again in windows explorer
%AppDATA%\Roaming
You can also reveal Hidden folders from Windows Explorer. Hide them again when done for security reasons.
do these answers remain on this form, so if I save this link I can come back to it? (I am new here)
a bit later and I am getting around to this task. I still cant get it to work. here is the video of my steps. baffling. can anyone help?
A few files are located in multiple locations in Revit now. (click here for article) you have to look under your personal user hidden folder appdata/roaming/autodesk/revit/ choose the selected product you are using and edit that shxfontmap.txt file.
