Many wall tag types for one wall type
5 ANTWORTEN 5
Nachricht 1 von 6
gnarkill283
2000 Aufrufe, 5 Antworten
I have concrete walls created based on structural drawings that do not include finishes. I had to add the finishes such as stucco and furring as separate walls against the concrete walls. I now need to tag the concrete walls themselves and be able to have multiple wall tag types for those walls. Is there a way to do this or do I have to create fake tags? Thanks
5 ANTWORTEN 5
Nachricht 2 von 6
hmunsell
als Antwort auf: gnarkill283
not sure i understand the issue... if you place the concrete walls and then placed the cladding as separate walls, why cant you tag the concrete walls?
Howard Munsell
Nachricht 3 von 6
Sure you can have multiple Wall Tag Families and Types in a Project.
BTW:  What do you mean by "fake" tags?
Nachricht 4 von 6
gnarkill283
als Antwort auf: barthbradley
When I make a duplicate wall tag and try to change the type parameter it still changes both wall tag types' parameters. So take for instance this highlighted blue wall - I need to tag it with multiple different wall tag type parameters but since that's not possible I'm faking the tags: image.png
Nachricht 5 von 6
That's the nature of a TYPE Parameter.  Sounds like you want to have a Wall Tag Label that references an Instance Parameter.
Instance Parameter – Enables you to modify the parameter value separately for every instance.
Type Parameter – Enables you to modify the parameter value, which applies to all elements of the family type.
Nachricht 6 von 6
hmunsell
like this..... these are actual wall tags tagging walls.
https://autode.sk/2Wa93D5
Howard Munsell
