Hi fellas!
I wonder if it's somehow possible to manually override the "spot elevation" function?
Would like to insert our own text instead of the actual plus height.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You mean not report the elevation at all? If so, why not use leader text annotation instead?
Well, yes. But I wan't the symbol to be the same. Guess I could create a similar family but it would be easier to just manually overriding the numbers.
Absolutely. That would be my suggestion.
