Managing Proffessional Stamps
Is there a way we can send our models to other people and consistently purge our stamp image from it? I don't believe eTransmit will do this if you have a stamp in the sheet with a yes/no visibility filter.
Our managers are worried about sharing a JPG of our stamps. Is there a smart way to manage these? I have to say this is slightly futile since they could just do a print screen on a set of PDFs and get the JPG, but I am still looking for a good solution to propose.
You can edit the titleblock families after eTransmit, remove the stamp from them and reload.
Lo-fi and tedious, but that would work.
Thanks!
stingers80-cgarchitect
I'm not quite sure about the problem.
If you have the Stamp inserted in the Sheet family as a JPG, when you create your eTransmit set, you can just delete that JPG file before sending out.
Why do you need to edit family and Reload?
Never mind. Sorry,
I see where the problem is..
