I have a door family within the door 2 door handles (nested families).
It is 1 door handle with multiple colors. So 1 handle family with 3 types (White, Black, Steel)
In each type of my door handle I choose a specific material. So a white color material on my door handle white and so on ...
I want in my project I can select my door and choose which handle I want for each door. So I create in my door family a door type parameter (shared parameter). And use it also in my project.
It is possible to switch in my project the door handles, but the color doesnt change ..
If I look in my door family and change the different types of handles, I can see the different colors. It just took my last change in my family before I load it in my project.
What is my mistake? I don t want to choose the material in my project, I want it is already done in the nested families.
See video
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Seems like the handle isn't parametrized. When you change the handle material type, only the inside switch the material.
