When I try to use the Manage Revisions tool, I receive the following error: "Object reference not set to an instance of an object." This is happening on multiple files.
Is there any known solution for this? I was using Windows 7 previously, am now on Windows 10 (brand new computer), and the updated OS did not solve the problem. No one else on my team (all using Windows 10) is having the issue.
Never seen this issue before. I first would look at the add-ins you have installed. It might be one of those that interferes. Try to uninstall them and see if it solves your issue. Otherwise consider reinstalling Revit.
Louis
Please mention Revit version, especially when uploading Revit files.
Hi @Anonymous
I see that you are visiting as a new member! Welcome to the Autodesk community! ![]()
Did you recently upgrade your file to a newer version of Revit?
Can you check if this issue occurs when you use the administrator account?
Please sign in to your Autodesk Desktop app. Check if your updates and hotfixes are installed for your Revit version. See HERE for information.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
