making opening in slanted wall
hei any body know how to make opening in slanted wall ?
because i have tried with shaft but it didnt work and the wall profile cant be edited n also i have deleted the mass. is there any way without recreating the mass ?
thx
If the opening is a rectangle then you can use Wall Opening tool.  If the opening is an odd shape then use a model in place (see below) or a family with void/opening cutting host.
syman2000
You can create inplace family and choose wall as your category
Then you setup void profile and extrude the profile. Afterward use the CUT tool and select the void and cut it with the wall.
As a result, you can get customized shape for your opening.
i got it thx  a lot but i use revit 2020
i got it thx a lot
