I am trying to make mass invisible but after applying transperent material also edges are visible
Why not use visibility/graphics overrrides and hide the mass category. Or if you need to show other masses, select the mass, right click and select Hide in view > Elements
Louis
Please mention Revit version, especially when uploading Revit files.
Select the Mass in the View, right-click and press Override Graphics in View: By Element in the right-click conceptual menu. See override options including Transparency. If you just want it hidden it entirely in the View, then press Hide in View: By Element in the right-click contextual menu.
