Making background Text transparent, changing the transparency percentage
Remigio.BaldoniH83XY
Good afternoon,
I was wondering if there is a way to change the % of transparency on the background of the annotation text. When I check the properites of the text, I can change from Opaque to transparent, but I can't adjust the level of transparency from 0 to 100 as per other objects.
Edwin.Rense
Seems like it's more of a Toggle function, either the background is visible (Opaque) or it is not visible (Transparent)
Within the Options you can only change the color of the background:
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-4E9F0CC4-5447-46A1-B291-F1D93F72DE4C
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Edit: never mind, it doesn't work.
"Try to create selection filter that includes the text, add it to the view and change the transparency %."
So you're after something like this?
Yes exactly, a semi transparent background for the text is what I would like to achieve!
Edwin.Rense
I Think I might have a solution/workaround:
I have created a new 'Detail Item' family (width/height are parametric) with the solid fill pattern in color White.
Than in the view set the detail items to transparency.
Or use the 'Comments' parameter to set to Background and create a filter for Detail Items with 'Comments' equals 'Background' to show transparent.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
