Can you export and make a SHX file from a Revit model. I have seen in other posts it is possible to make one from Autocad file, however can it be done from Revit?
SHX is AutoCAD font file. Are you confusing this with SHP file? To do this you can export your Revit to DWG/DXF. Then download the QGIS to convert the DXF to SHP.
https://paulcrickard.wordpress.com/2012/10/25/shapefiles-in-revit-method-ii/
