I AM CREATING A FAMILY AND I NEED AN EXTRUDED CIRCLE IN THE MODEL BUT I NEED IT TO CHANGE SIZE AND I CANT SEEM TO FIND A WAY TO MAKE IT DO THAT HERE IS A SNIP OF THE ERROR IM GETTING. AND IDEAS WOULD BE EXTREMELY APPRECIATED THANKS.
Gelöst! Gehe zur Lösung
Gelöst von jdiala. Gehe zur Lösung
Was this question ever answered. I have never been able to change the diameter of an extrusion in a family. I would like to have an instance variable on diameter of a fluid vessel or a can light. I keep getting errors when trying to assign a diameter dimension to the diameter of a round extrusion of a barrel or can. And would be great if we can get voids to operate the same way.
Many years later and not a solution yet?
Edit the extrusion and add a parameter to the radius or diameter of the circle sketch.
I think the trick is to attach the dimension BEFORE you close the extrusion.
You need to add the dimension for either radius or diameter when you are still in the extrusion sketch mode and then assign a parameter to that dimension.
