Is it possible to make the window visible in the floor plan (display it as if it is cut) without having to:
P.s.The window is positioned at 1.6 m and the cut plane is set at 1.0 m.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
no
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Thanks for the reply. For now, I used the Line Work command with the help of overlay looking up.
