How do you make room separation lines visible? I followed the exact steps from this link... https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN... ...but my room separation lines are still invisible.
Gelöst! Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
I suppose you have created these Room Separators...did you? Because you had to do it manually..
Constantin Stroescu
I'm also assuming you did draw these lines manually. What could be the case, is that a floor is above the level you are in. Room separation is a 3D line, so it can be buried in your floor.
That was it. I switched to wireframe and could see it. But what elevation does it go to when its being created? Because my rooms base stop at the finish floor. I would assume the line would go to bottom outline elevation of the room itself. Why would It be in the floor?
