Make lines invisible
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
6349 Aufrufe, 4 Antworten
H all. I have some lines in section that I want to pick them up an make invisible in view. I dont want to right click and hidde in view. I know there was another easier way to do it, any ideas? Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
loboarch
als Antwort auf: Anonymous
The linework tool does this. Select <Invisible Lines> for the line you want to go away.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-8979FAF8-8E25-4977-BFC8-0C065654CD0E
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 5
fespino
als Antwort auf: loboarch
Please EXPLAIN why Linework does not sometime work, specially <invisible> lines when trying to select
lines in plan view of a concrete beam in plan. There is no answer to this anywhere I could find
Nachricht 4 von 5
cbcarch
als Antwort auf: fespino
Try isolating the concrete beam, then use wireframe view when using linework tool to select lines which are hidden.
Did this work?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 5 von 5
fespino
als Antwort auf: cbcarch
No
