In Revit 2025, pushing the Macro - Run button closes the Macro dialog. Then when you reopen the Macro dialog the module tree is collapsed. So you need to re-expand the desired module and re-select the previously selected macro. Would be great if the dialog were modeless or if it remembered the expand/collapse state of the modules and which macro is selected.
The link I had saved for bug reporting is orphaned... but maybe someone can find the way to report bugs to A-Desk. Alternatively contact support.
If this is just a missing feature, post here:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
oops - thought I was posting this in the "ideas" board. Here is the "idea" https://forums.autodesk.com/t5/revit-ideas/idb-p/302
