Make guide grid printable
2 ANTWORTEN 2
Nachricht 1 von 3
1024 Aufrufe, 2 Antworten
Hi
For a class I need to print a custom titleblock with a grid. I could have done it with autocad but wanted to do it with revit, I need the guide grid to print and can't find nowhere how.
Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: Anonymous
@Anonymous
It is a non-printable in Revit. You can create a generic annotation with the same spacing and place it on sheet
Nachricht 3 von 3
You could build the Grid into the Title Block Family as a parametric Array that you could control the spacing or visibility of per Instance in the Project.  TIP: Place Grid Lines on a Subcategory of Title Blocks Category so you can control Line Weight, Pattern and Color independently of the other Title Block line work.
