how to make the mullion continuous to the vertical mullion? it was a edit profile curtain wall. thanks
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Can't do it while in edit profile sketch mode. Close out and toggle mullion join
It's a curtain wall mullion? You didn't model it in place by any chance?
So you did model it as an IN-PLACE COMPONENT? If so, you are out of luck then. Why don't you just use the profile to define a new Mullion Type and apply that Mullion Type to the Curtain Wall Grid? That way, you'll have the controls I mentioned above.
This is a tough one. I found the best solution was to Split the Wall -- NOT Edit it's Profile -- making it into two separate Walls; one on top of the other. Once Split, I changed the length of the ground floor Wall, and made the necessary mullion modifications.
See attached.
p.s. What happened to the System Empty Panel?
Here is a version not using edit profile, but remove the lower grid segment and change the lower panel to Empty (I transferred it from the Metric Template).
ok i got ,it but how you did it. you make it as one curtain wall and change it to empty panel (below), what happen to the grid ? did you remove? how you add the empty panel? can you please explain. thank you
- You can TAB select a grid and use Add/Remove Segment from the toolbar and click on the Segment(s) you want to remove. That will remove the mullion(s) and merge the panels
- Select the merged panels, unpin, and change them to Empty System Panel to remove them
- You can select a row of mullion on a grid line and Make Continuous or Break as you like
See revised file.
@barthbradley sorry, thank you , but i think i followed @ToanDN approach more desirable. thanks
@BIM_Dreamer wrote:@barthbradley sorry, thank you , but i think i followed @ToanDN approach more desirable. thanks
What the heck are you sorry about?
For the time you spent making the solution.thanks
Ah, I see. No need to apologize. If you valued the time and help we both gave you, then give us both a solution credit. You're not restricted to just choosing one. Besides, both of us provided a viable solution. Neither approach was "wrong".
