make color scheme for walls
bahram_babai
bahram_babai
Can I have a colour scheme for walls. I'm making a separate template for Fire safety plans thanks to the folks guidance here I already made a scheme for deferent room based on the fire rating. now can i have make another colour scheme parameter under view properties on view template and then assign colours to wall or any other element. in part of using filters...
RDAOU
@bahram_babai
unless it is a chraiteria defined by an already existing wall property/parameter (example: Volume or Level or Height...etc),
  • add a project parameter to walls call it XYZ Walls Color scheme
  • Go to view >> graphics >> Filters
  • Add a new filter
  • Check Walls from the list of catergories
  • Use that parameter you have created above
  • filter using equal
Once done with creating the filter, apply it to the view or add it into a view template which you already have
bahram_babai
beside using filters can we use colour scheme for walls?
arq_42
In my study, we use coarse level detail for the wall typology plans.
In the type properties of each wall, you can select the color for each type.
Beyond that, the best, easiest, and most versatile option, as you've been told, is to use view filters.
If you want a method similar to the room and area color scheme, you can request it in the ideas forum.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
RDAOU
@bahram_babai
It depends what that scheme is for and what you wish to present…you did not specify in the original question
nonetheless, filters is the easiest and quickest without having much impact on the elements you modeled. On the other hand, if it is a material on internal elevations what you wish to present, you can apply the color to that materials under it’s graphics tab
many also prefer to post edit such presentations outside Revit where one can be more artistic and creative
