Make all layers in linked CAD file one colour
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
emmanuelbee
2451 Aufrufe, 9 Antworten
Is there a way to make all the layers in a linked CAD file one colour so that i want have go through the visibility grahpics of each view and change the colours manually? I thought I could do this by changing the settings in 'Object styles' but for some reason even though I change all the layer colours to black in the settings, some of the original colours the cad file does not change. is there another alternative to solving this?
9 ANTWORTEN 9
Nachricht 2 von 10
RobDraw
als Antwort auf: emmanuelbee
Have you tried modifying the .dwg before linking it in?
Rob
Nachricht 3 von 10
emmanuelbee
als Antwort auf: RobDraw
modifying it in what way?
Nachricht 4 von 10
RobDraw
You're the one that said you wanted all the layers the same color. Did you have something else in mind?
Rob
Nachricht 5 von 10
brettgatti
Try assigning all objects in the AutoCAD file to Color "Bylayer".  That should give you better control when it is linked into Revit.  There is still a chance that some items (embedded in blocks and assigned colors - not Bylayer) may not change color in Revit.
Nachricht 6 von 10
emmanuelbee
als Antwort auf: brettgatti
Those colours are company standard colours so the aim is not to change the colours in cad, they have have to stay the same. In revit however I'm allowed to change the colours.
Nachricht 7 von 10
emmanuelbee
Nachricht 8 von 10
RobDraw
You could make a copy of the file and make the necessary changes.
Alternatively, there is an option in the import dialog to change the colors to black and white.
Rob
Nachricht 9 von 10
Just select the link, right click and override element in view, then change the line color. Make it as a selection filter so you can apply it to a broad range of views.
Nachricht 10 von 10
emmanuelbee
als Antwort auf: ToanDN
Brilliant Idea! Thanks
