Make 2 mullions into 1
drew3070
drew3070
Is there a way on to make the highlighted C01 mullions below merge into 1 for each pair of mullions? The grid system is 24" x 24" but C01 mullions are supposed to be 48" in length.
RDAOU
@drew3070 Mullions start/end points are associated with Grids intersection. Unfortunately, as long as the intersecting grids are there, it is neither possible to join, nor to extend or model them as 1 mullion that runs over a grid intersection.
Basam.Yousif
You really can't.
You can only make it LOOK like that if you remove the GRID segment, then 'make continuous'. If you must, you can delete the mullion then make a panel family that looks like two panels and a mullion 🙂
