M&E linked file - how to control visibility?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
773 Aufrufe, 4 Antworten
Hi
I have a M&E file linked to the architectural file.
I want to print an elevation but I notice there are few crosses from the M&E model on it (highlighted in the file attached). I try to turn it off on 'View Properties' - Revit link, but apparently I cannot control it.  Any ideas?
In addition, I am also using the M&E linked file to produce a section. However, there are pipe systems that I cannot override using filters (highlighted in the file attached). Again, any thought on that?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Open the graphic overrides within the view go to Revit links and uncheck the viability. you can also use this to change the graphic display of the pipes in your section by editing the display settings for the link. (on the far right of the dialog box)
Nachricht 3 von 5
Hi Graeme,
I don't want to turn off the M&E model. only the crosses.
Any ideas?
Nachricht 4 von 5
Ah, apologies i miss understood. Within the links display settings if you change it to custom and within model categories turn pipe centerlines off should solve the problem.
Nachricht 5 von 5
Great! It worked!
Thank you very much!
