Lumion perceives the wall as a whole
3 ANTWORTEN 3
Nachricht 1 von 4
maideniz96
693 Aufrufe, 3 Antworten
Lumion perceives the wall as a whole. As seen in the screenshot, I assign different layers to the wall and different materials to these layers. When I transfer the model to Lumion, the wall appears as a whole and I can assign a single material. This is also true for floors and other building elements. It does not detect window as case and panel. Likewise, BIMOBJECTS has the same problem.
Tags (3)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: maideniz96
Did you use Lumion Live Sync or export to FBX?  Live Sync should not have this problem.
And, Lumion reads materials' appearance so you need to have different appearance assets for different materials.  Edit material, switch to Appearance tab to check and fix if necessary.
Nachricht 3 von 4
maideniz96
als Antwort auf: ToanDN
i work on two different computers since one has licenced revit, another has
licenced lumion. so i exported a fbx file. i tried importing fbx file to
blender then exporting again but didnt work.
Nachricht 4 von 4
RDAOU
@maideniz96
You can install Revit on the workstaion with Lumion?? :leicht_lächelndes_Gesicht:
Which version of FBX are you exporting?? try the older ones....Otherwise, If you have Formit, you can send the Revit to Formit and export the fbx from Formit  and it works for sure
