Low Wall Behavior
Low Wall Behavior
PhilvK
Advisor Advisor
Low Wall Behavior
PhilvK
I'm aware that low walls don't cut below 6', and there are tricks that you can use to get around this, but I have a low wall that does show the exterior layer only when cut. Any ideas why?
hmunsell
if the wall is set to go from Floor 1 to Floor 2 (12') BUT has a negative top offset (-7') making it shorter than 6' it will still show layers.
Howard Munsell
PhilvK
Very interesting. Your solution worked great in another project, but not in the one I started with, but it does work. Thank you!
hmunsell
Kewl, i actually never new this was an issue and i have been using Revit for 21 years. when i read your message i had to try it and i was surprised it didn't work LOL. so i started racking my brain about how wouldn't i draw a wall.
Howard Munsell
