Louver family denies instance height in Revit 2020
6 ANTWORTEN 6
Nachricht 1 von 7
eyalbRAPVR
774 Aufrufe, 6 Antworten
Anybody knows why is it that I cannot have the instance parameter stretch condition in when I host a generic family inside a curtain panel family in revit 2020. It was possible in previous versions. Any idea?
I attach the file in question...
6 ANTWORTEN 6
Nachricht 2 von 7
kpatel2QWBH
als Antwort auf: eyalbRAPVR
I believe you wanted to use the Louver Height Parameter created in Louver Array family in Parametric Louver Panel Family.
The steps area s follows:
1. Go to Parametric Louver Panel Family > Interior Elevation > Add an aligned dimension for the height > Create parameter > Name it > Select Instance as the option > OK.
2. Now select the Louver Array Family > Associate Louver Height Parameter with the new parameter created.
Now you can change the height as neede.
Hope that works.
Nachricht 3 von 7
martijn_pater
You're not using an instance parameter in the nested family. But actually you should just associate a dimension parameter in the main family, either top of panel or with additional reference planes. Associate it for all nested families. Also I think you could do this with less nested families...
Nachricht 4 von 7
martijn_pater
als Antwort auf: martijn_pater
Ow, perhaps you dimensioned to level instead of reference plane... (which is weird because I thought that should work also actually...), but trying to use shape handle control with array function doesn't really seem like a good way to do that, associating parameters gives you more control.
Nachricht 5 von 7
eyalbRAPVR
Thank you all. I will try everything again. I built such families many time and never encountered such weird behaviour. I will try all variations again. I even tried nesting the louver directly into the panel family and arraying it there and still it did not stretch to snap to the top reference plane.
thanks anyway...
Nachricht 6 von 7
You need to create an Instance parameter for Height in the family and associate the nested Louver Height parameter to it.
Nachricht 7 von 7
martijn_pater
See attached, for your reference. Have a look at how the nested louver family with shape handles behaves in an array and why that doesn´t do the trick...
