Lost Wall
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
256 Aufrufe, 4 Antworten
Lost Wall
Hi, I've just noticed in my South elevation that the outer wall is missing yet it appears in the 3D view?  I have checked the Reveal Hidden Elements tab and the only thing seemingly highlighted are several red circles which are the ends of the structural columns.  IS there any other way I can find out why its not showing and put it back in view?
4 ANTWORTEN 4
Nachricht 2 von 5
Sahay_R
als Antwort auf: Anonymous
Couple of things -
1) Make sure that wall is not on a workset that is not visible
2) Make sure you don't have any rogue filters
All else failing, delete the view and re-create it.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 5
semko_dm
Hi!
Here is <the list of possible reasons>.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Nachricht 4 von 5
als Antwort auf: Sahay_R
Had to recreate the views as none of the 33 choices also suggested were applicable.  Have no idea why that would happen but hey ho.  Thanks
Nachricht 5 von 5
Your wall was probably behind the elevation line.
