Hi, I've just noticed in my South elevation that the outer wall is missing yet it appears in the 3D view? I have checked the Reveal Hidden Elements tab and the only thing seemingly highlighted are several red circles which are the ends of the structural columns. IS there any other way I can find out why its not showing and put it back in view?
Solved by Sahay_R. Go to Solution.
Couple of things -
1) Make sure that wall is not on a workset that is not visible
2) Make sure you don't have any rogue filters
All else failing, delete the view and re-create it.
Hi!
Here is <the list of possible reasons>.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Had to recreate the views as none of the 33 choices also suggested were applicable. Have no idea why that would happen but hey ho. Thanks
