Hello All.
I can't find in the coordination layout the background, as you can see in this photo.
But I can see it in the architect layout:
The problem is that I don't know what's happening.
Gelöst! Gehe zur Lösung
Gelöst von azad.Nanva. Gehe zur Lösung
Here's a handy cheat-sheet to reference when you can't see something in the view.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
If none of the 33 apply, then post your RVT here and we'll see what the deal is.
you change your view Template from Working View to the Architectural Plan and your Disipline is changed by the View Template.
you can uncheck the include in the viewtemplate and do it by yourself not automatic.
for example:
