When i am working in Revit 2015 i can set up a windows of views in certain order and after reopening a project i still have same order from before closing project. When i am working on project using Revit 2017 every time i reopen a project i have to spend some time setting up windows to the way i like.
What is the solution?
Kind regards
RN
Kind regards
RN
Gelöst! Gehe zur Lösung
Can you provide a bit more information...are you referring to the order of views on the Project Browser, or views you have tiled?
I think you are referring to tiled views...I did some testing and they will stay the way you want, if when you save and close you are in the top left view...otherwise, if you save and close in one of the other views, it will make that the top left view when you WT
Well not tiled exactly, but close enough (on one monitor plan, on second 2 sections).
Tried your way (views set up as tiled) and still not working.
Kind regards
RN
Any idea how to solve this?
I am tired of loosing time seting up windows every time i work in Revit.
Kind regards
RN
I found a solution (i guess i am at point where i can find it myself).
You need to go:
Click Manage tab / Manage Project panel / Starting View
and set as a starting view - last viewed (got polish version so not sure if that is exact translation).
