I'm working on a project to reconstruct Pliny's villa at Laurentum and was wondering if there is a template or how I could create a template better suited to this than "residential-default."
@hutchinss wrote:I'm working on a project to reconstruct Pliny's villa at Laurentum and was wondering if there is a template or how I could create a template better suited to this than "residential-default."
Better suited how?
P.S. I think you might be misunderstanding what an RTE is actually all about.
When it comes to HBIM ( Heritage or Historical BIM) the problem that arrives is a dedicate Families Database not the Template itself.
I recommend using an Additive Template completed by a large customized specific Families Database (Columns , Doors, Windows, Cornices and Profiles for Walls, and so on).
Unfortunately , it will be very difficult to find these Families as readymade ( sure not for free) and , anyway , not exactly what you need ( so there will be necessary some extra work on them).
The database creation needs a large amount of work usually in a team.
In order to achieve your purpose, I recommend the following books/links:
Paul Aubin: Renaissance Revit : Creating Classical Architecture with Modern Software
https://paulaubin.com/books/renaissance-revit/
https://arrow.tudublin.ie/builtdoc/17/
https://www.autodesk.com/autodesk-university/class/Parametric-Modeling-Vaults-Notre-Dame-Revit-2019
https://www.autodesk.com/autodesk-university/class/Discovering-History-BIM-Project-Notre-Dame-2019
Constantin Stroescu
