looking for FM(facility management) solution compatible with Revit and Forge
5 ANTWORTEN 5
Nachricht 1 von 6
takeokaE5KAS
501 Aufrufe, 5 Antworten
I would like to know most user friendly and fair prices FM solution around the world. An FM solution compatible with Revit and Forge is good. Please exclude Archibus and Maximo and FM systems. Could anyone please tell me about it. I apologize if this question should not be written in this forum.
Thank you.
5 ANTWORTEN 5
Nachricht 2 von 6
Mohamed-Nassar
als Antwort auf: takeokaE5KAS
You BIM
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Nachricht 3 von 6
RobDraw
Obviously, you have looked into this and found some that you don't want. It would be helpful to know why they are not acceptable.
@Anonymous might be of some help.
Rob
Nachricht 4 von 6
takeokaE5KAS
Thanks,  Mohamed-Nassar and RobDraw.
I will contact MistressOfTheDorkness.
Nachricht 5 von 6
RobDraw
I think she goes by the wanderer or something similar, now.
Rob
Nachricht 6 von 6
lol I was searching for this thread forever after you tagged me and couldn't find the mention in my profile... now I ran across it... my old profile was tagged, which I can no longer use, so it didn't show up in my current profile.
Fun times.
To the OP, can you tell me more about this Forge compatibility? I've not heard of any CAFM vendors specifically tying into that myself, but obviously the ones you mention, and Tririga and probably others do work with Revit.
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
